sileightysomeday »
https://forums.nicoclub.com/sileightysomeday-u27251.html
Mon Apr 16, 2007 9:48 am
im using the KA speed sensor. I think maybe when i cut and connected the ECU to the chassis harness maybe one of my splices weren't connected well enough, i looked at it and it seems ok, but all i did was twist the wires together and put liquid tape over it. so maybe it's not reading to the cluster. but when i had my SOHC to DOHC swap on the same car, the gauge cluster read just fine. but the engine is still doing the same thing, it seems like it's misfiring. the engine is shaking, and sounds like a WRX. and idles fine for alittle bit, then dies if you leave it alone. any other suggestions?
