jr_ss wrote:Touge, you need to get it tuned to be running 550cc's. You'll wash down the cylinder walls and eventually fill your crankcase with fuel... Although that might not be the issue, the injector o-rings could be. Make sure they aren't leaking/broken/rolled and that they are lubed, non petro based lube will help seal. Leaking around the orings could occur and you'd have a very hard time finding that.
PantherRacer wrote:also, what is your fuel pressure and what FPR/fuel pump are you using? when my car was doing this my pressure was off.
The O-rings are good. I checked them before I put them in and I even got a diagram from SaRD to make sure I had them assembled right, however I never put any lube on them. I am ordering new injector spacers and an FR aeromotive FPR so I'll check the O-rings again and put some of that lube on there when I take them out. As far as tuning goes I am going to run either a J or D-Jetro Power FC, haven't decided which one yet but I am leaning towards D-Jetro so if I ever build the motor I will not have any problems with a MAF.
Hmmmmm.... Also, I didn't mention this earlier but when I first completed my swap I wasn't getting any power to my fuel pump. It turned out that for some reason the ground wire coming from my fuel pump relay wasn't getting a complete connection and I never did figure out why. What I ended up doing was grounding it to the chassis and installing a switch so I control when the pump turns on and off. I don't know how that setup is supposed to work; does the ecu tell the fuel pump relay when to turn on and off so that there is fuel cut when needed? If so then I need to find out what to do about this.
Modified by Touge' at 2:18 AM 11/10/2008
