s14 sr20 rough idle
[TRE05]97ka24DE
Car: 1997 Nissan 240sx KA24DE
I finally got my swap running but it now has a rough idle. Its wierd because when it first started it was running fine. when I couldnt get it started at first I realized I had a bad CAS so I swapped it out and it ran great. but anyways. when I start the car it rpms at like 2000 which is high and the engines shakes alot like it trying to stall. once over 2500 when driving there are no issues. so any ideas?
Sil80315
Car: 1991 Nissan 240sx
Try cleaning the IACV, Check for boost leaks, and make sure all your sensors are plugged in. Last but not least Check your ecu for codes if its throwing any
[TRE05]97ka24DE
ok I took out the whole upper intake (IACV is on top since it an s14 sr20) took the IACV off cleaned it real good and checked for vacuum leaks. I think I found one underneath of the IACV, there a pipe that goes to it and some of the gasket material was cracked. I replaced the gasket and put it all back together. when it starts it goes to 1000 rpm which s way better. but after about ten seconds it starts idling like crap again. anyone else got any input?
Sil80315
Check o2 sensor or temp sensor.. Its throwing timing
[TRE05]97ka24DE
how can I check the ECU for codes??? it a s14 sr20 "NA" code ecu. on this ECU there is no light that blinks. So how can I check it. also The wiring was done by a pro if that helps.
Sil80315
there is a consult wire that should of been the wired for the gauge cluster plug. the wire is orange and if its wired into your cluster then you should see the CHECK ENGINE light on in your gauge cluster when you turn the car ignition on but NOT starting the car. from there you take a small Phillips screw driver and turn the small screw on the ecu clockwise or counter clockwise till you get code flashing from the check engine light on the gauge cluster. from there you just look up the code.
just remember long flash is the first digitshort flash is second digit1.5sec pause is between each code that will read out.
if you count code 55 then its normal
[TRE05]97ka24DE
this sucks!!! the NA s14 kouki sr20 dosent have a light or the knob!!!!! but I think I figured it out. with the 02 sensor unplugged the car runs way better I think its a bad 02.
