[TRE05]97ka24DE »
https://forums.nicoclub.com/97ka24de-u83072.html
Tue Sep 29, 2009 12:10 pm
I recently installed ans s14 sr20 into my kouki. I rebuilt the motor bottom end with ACL bearings, and put on a new metal cosworth head gasket. I also have a custom intercooler kit. well anyways the engine isnt running as it should. first off when you start the car the rpms jump to 2200, then after about ten second the idles around 800, but is some what rough. MAFS and 02 sensor seem to be working because when I unplug them while the engine is running it affects performance. Im goin to the store to buy mass air flow cleaner, new plugs, and injector cleaner. To see if it will do anything to help. any input would be very helpfull. I will post videos later on tonight after i install new plug and clean the MAFS. Thanks
