robtheflyer wrote:I've searched this topic, and besides a bunch of alternative smoggine methods, I havn't seen the answer for this yet. Do s14 notchtop sr20det ECU's comply with OBD2? I'm wanting to know if you swap a s14 sr20 into a OBD2 s14, will the OBD system still work? My local mechanic is an inspector and all he needs to do is hook up to OBD system and verify no codes, any help would be appreciated. Thanks.
the sr20 is OBD1 only. although, with some creative wiring ,maybe a rom flash, and an obd2 ECU you could probably find a way to spoof a scanner.
