Kouks »
https://forums.nicoclub.com/kouks-u27952.html
Thu Apr 08, 2010 4:28 pm
I have a s14 sr20 as previously stated. s15 spec r turbo(10 lbs.), Greddy FMIC/DP/3" Cat-Back, Free flowing Intake. 370cc stock injectors, stock MAF, stock computer.
Makes 250whp. My problem is between 2k and about 4k(basically just lower rpm), anywhere from half throttle to wot results in seriously lean condition ranging from 15:1 to 17:5 a/f ratio as seen on my wideband, as well as dyno sniffer that was just put into the exhaust, read the same thing as you can see...heres the dyno sheet for proof, as well as maybe some helpful insight...
It occasionally has a idle problem, holding various rpm to maintain a good idle, or upon decel might fall all the way to 500rpm and then bounce back to 1k. could be a different problem, i could see a vacuum leak causing both of these problems though, so it was worth noting....
What I want to know is where do I start looking for this problem...the a/f falls back down to around 11.5:1-12.0:1 closer to redline, so it doesnt seem to be starving for fuel up top, so why is it down low?
my compression was 125 warm across the board. going to check IC couplers in the morning for excessive cuts/holes etc...my vacuum lines are minimal, and a pretty clean thorough swap..I can check fuel pump voltage tomorrow as well...
Anyways, i could continue to stipulate various scenarios, my thoughts on this, but thats why im here, to here someone elses opinion, maybe someone sharing my dilemma, search didnt reveal anything prominent.
shoot!
Modified by Kouks at 7:43 PM 4/8/2010
