I think the isses are the varible timing wiring is a bit tricky and if you get a FMIC, the hotpipe needs to be custom modified because it won't fit under the hood of the S13. Other than that, I understand it to be quite similar to the Redtop.
I have an 89 so I need to redo the power steering lines, and the cluster, should i just get an s13 front clip instead because that will all already be installed?
trixracing wrote:Is it really that much more diffucult though?
I would get the S13 clip... it will have everything to make your car run like new... JDM new
