S14 sr20 into 95 s14 swap question
Trppen37
Car: CA18DET
I just finished doing my s14 swap into my 95. I cant figured out the wiring with the fuel pump relay. I cant hear it coming on and wasnt sure how to hook it up so i just guessed. can anyone help with this.
Nismo_Freak
Car: 89 Nissan 240SX
Trppen37 wrote:I just finished doing my s14 swap into my 95. I cant figured out the wiring with the fuel pump relay. I cant hear it coming on and wasnt sure how to hook it up so i just guessed. can anyone help with this.
Why not hotwire it with a relay, using the ignition "ON" as a power source for the relay?
Or you can test for voltage out of the ECU at the black / purple wire and trace it over to the fuel pump relay (located in the driver's side left footwell area) and check the relay for power.
Spins
Car: spending too much money on my cars.
Mine is wired that way. Just dont turn the key on leave it without starting the car. If I do so my car seems like it floods.
Trppen37
Car: CA18DET
were gonna try that tomorrow and see if anything works....its really annoying that the car cranks but doesn't start..
dreadedboost
Car: 90 240, 97 3000gt vr4
nismofreak, i know this may be a lot to ask but can you help with the rest of the wiring that deals with the white connector behind the ecu. this is trppen37 BTW thanks
