J14cm7 »
https://forums.nicoclub.com/j14cm7-u149038.html
Sat Feb 27, 2010 8:09 pm
STOP. Your idle issue has nothing to do with your BOV valve. Assuming its in good working order. Your BOV isnt even doing anything at idle. The only thing your BOV causes your car to is fool the MAF into thinking there is more air going into the engine and cause it to run rich and stall after big runs.
If you have an S14 sr like me and you have the stock intake pipe there is an 29mm outlet on it. Make sure you order the 29mm outlet fitting for the BOV and then you dont have to worry about installing a reducer on your tube or making a new inlet spot on your intake pipe going to your turbo. I ordered mine today the stalling is just to annoying. Unfotunatly its twice as much as the 1" outlet.
