S14 sr20 Clutch alignment tool??
newdude1
I heard the ka24 has the same tool needed for the sr20. Is this true? I need it to realign my clutch.
CoupedUp
Car: 1993 Coupe
I think they are the same?
To make sure, it needs to be 24 Spline x 25.4mm(1 Inch)
fast_s13
its the same
757coupe
dude i want to come see your swap i havnt seen your car around at all, do u drive it much.hunter
newdude1
Na I havent driven it much. My rear main went out on me and my trany is leaking from everywhere basically lol. You got an account on vadriven?
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
newdude1 wrote:I heard the ka24 has the same tool needed for the sr20. Is this true? I need it to realign my clutch.
it is the same...you can you use a socket, or broom handle if you don't want to buy one. I do it all the time when I don't have a tool. Never had an issue.
240_SeX
Car: 1992 240SX SE
i used a trans with the bellhousing off on the last one it did, just slid the input shaft in...Couldnt find my tool.
But yes, they are the same...The trans in the same
Hijacker
Car: '92 240sx Convertible
'94 F-150
Best alignment tool I ever used was the sliced off input shaft from a transmission.
