s14 sr wont start
grubby27777
Car: s13 RB26, hatch with s14 sr
Ok about a week ago i picked up a s13 hatch with a s14 sr, pretty stock, had a front mount and turbo timer, nothin special. i bought the car from a marine who had been over seas for awhile. the car hadent been started in 2 years. so i drained out all the old gas, put in new gas, changed the oil, coolent, all the little stuff, it took alittle work to get it started but with alittle starting fluid i got it goin. so i let it idle and warm up and then took it around the block.
I come back and turn it off and the next day i try and start it and it will crank, has spark and fuel, but will not fire. all help will be appreciated thanks
fast_s13
check your timing
grubby27777
timing set, problem solved thanks
