Postby
E7-S14 »
https://forums.nicoclub.com/e7-s14-u42538.htmlSat Sep 27, 2008 9:06 am
After my swap my tach didn't worki bought the car as a shell(no motor) and dropped the sr ini amused the tach worked..
well the guys that wired my swap said that the problem was in the tachometer itselfso i bought another gauge cluster with a working tachand it still doesn't work.
What else could it be causing my tach not to work?
everything should work since its a 96 S14 SR in a 95 s14 chassis
If i were to buy an aftermarket tachometer what rpm signal should i use to ensure it will work?
