Thoughtful_One wrote:Just had an S14 SR swapped in.
Problem 1)- The car just does not pull. Has a flywheel, Exedy Stage 2 clutch, turbo elbow, down-pipe, testpipe, HKS Hi-Power. Feels like a 1.6L Civic. Running 9-10 PSI, confirmed by a gauge.
***Problem 2)***- Car misfires under load after 5500 RPM. New NGK Iridiums with .03 gap, checked:- the coil-packs with known good ones - ignitor- TPS- CAS- timing -------Everything is checking out.
Please help. I have no idea what the problem is. I should be getting the car back tommorow. I'll refill with 92 and throw some octane booster in it for the mean time.
Modified by Thoughtful_One at 3:30 PM 12/3/2007
Modified by Thoughtful_One at 5:33 PM 12/3/2007
My problem turned out to be my injectors.
Shop took a closer look at them and they are 550 CC injectors out of a Twin-Turbo RX-7. Ran them with no tuning, hence the bad acceleration.
