s14 sr into s13. which drive shaft to order?
statickx991
hey i have a 1990 240sx auto that i just put a s14 sr20det into and made it stick. i want to order a drive shaft (1 peice aluminum) but the thing is do i order a s13 one or s14.? i tried the ka24de 5 speed one that i picked up and im not all about that. please help me
jcquick
Car: 95 Nissan 240SX w/ S13 SR20DET
Hit up Shaftmasters, they are one of the Nico Sponsors. Or take your shaft to a good driveshaft shop and have them make one from scratch. You eliminate that stupid center bearing and loose some weight. You also get the most commonly used U-joints and yokes, in case they ever go bad. You should probably change out the transmission and differential fluid. Good luck
Chukidori
You should be able to use the S13 drive shaft..
The transmission is the same for both cars...the drive shaft on the S14 is only different by length, because the distance to the diff is different
statickx991
ok i cut the dust cover off the tail end of the transmission so that huge *** rubber thing that i wish was a u joint doesnt hit it and now i got the s13 one to fit, but there is about a half inch of the yoke sticking out and i was wondering if that will hurt or anything, if you want i can get a pic
