Ok i just recently did an s14 zenki sr into s13 chassie. I followed "mestizo" wire up thread and I might say it was very helpful and did a kick *** job. So I wired up everything and Im getting power to everything MINUS coilpacks. The ecu is reading CAS code but im getting voltage to the cas and i even replaced the cas with a spair just to make sure And Im getting the same code. All my grounds are hooked up and i even ran another ground off the black ground wires that go to the ecu to the chassie and that didn't change anything.
If anyone has an idea on what this could be or if someone had this problem and got it fixed id really appreciate it.
Thanks
