I am in the middle of doin this same swap in my S14, and we rewired the m63\f3 connection, and everything is working except im still not gettin fuel or spark, cant figure out why, everything else on the car is working fine, fuel pump is turning on, but no fuel goin to the injectors and no power to the injectors, power goin to the ignitor but no spark, any help would be greatly appreciatedSilvia007 wrote:Like sil80 says, all you need is the mafs, ps, to be extended. The most you would have to do is move some wires on the power plug around. If you need pinout for the S14 SR Powerplug. Let me know, and yeah, I agree, "EVERYTHING" is for the S13. I had to search till my eyes popped out to find any info at all.
How can i figure out what year my motor is, i bought just a motorset...also i have heard that USDM zenki and kouki wiring is completely different, im completely stumped on this wiring right now, cant figure out the problem, and it aggrivating as hell. this swap has been goin on for almost 3 months cause of this problem and i cant get any answers and would hate to have to tow my car to a expensive shop to get it fixed... any help would be GREATLY appreciatedDriftBandit wrote:I have the zenki s14 motor in my 1995 s14 running good and everything, If you need help and have the same setup I would be more than happy to try to help you. I know how crazy looking for s14 motor info will make you.Good Luck-Jon
congrads on gettin the car running, did you run into any problem?, do you have the pinout of what you moved around on the f4\m63 connection? please help!!! im desperate, i have a 98 kouki, with a zenki motorsilvia-junkie wrote:thx for the reply guys but they came to late. the engine went in and the car runs great
That's not a bad Idea, it's all the info I could find on s14 sr to s14 chassis swap. We just need to add some more info to it.ca18det_boy wrote:good info.....sticky?
On S14 SR into S14, or S14 SR into S13?574-240sx wrote:I'm having some problems on my wiring. The harness was sent out and so far doesn't look like the wiring is right. I will get more in depth with it this weekend. I seem to have a ecu power problem.
the later VVT S14 motor going in a S14 kouki. i'm also having problems with the gauge cluster too. The plug is fine it was loose but fixed. I had to hot wire the starter to get it to start. Hopefully I will get into it more this weekend. To many projects and commitments and not enough time and money.SpeedRacer1 wrote:
