No. The S13 and S14 F4 plugs are different.vocationalzero wrote:will the fr sport wiring guide not work?:http://www.frsport.com/SR20DET....html
What confused me while reading through that is the ECCS relays part.david200095367 wrote:http://zilvia.net/f/tech-talk/....html
that should be about everything you need to know. installation wise the motor is a direct drop in.
Granted, I don't have access to the car at this moment, but I could have sworn I had two down there. . .This is the blue and white boxes roughly an inch high, correct?
God this is going to suck for me. I know practically nothing with wiring or "repinning" a harness. Dun du duhhhh.
yes you dont have to repin the relays if thats what you are saying.CRyan wrote:
