s14 sr in s13 piping?
1992MaxSE
Car: 91 240SX w/S14 SR
Im trying to figure out what intercooler piping i need to get. I got a kit which i thought would fit the s14sr in the s13 chassis but it seems to be for the s13sr. Do i need to get the hot and cold pipe for the s14 chassis to make it work?
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
Do you have pictures or names of the products involved?
1992MaxSE
I got this kit from cxracing.com off ebay
Steve Lloyd
you need to buy piping for the ENGINE not the chasis. So if you have an S14 SR then you need S14 piping.............
1992MaxSE
thanks... i appreciate the help. could i get away with just replacing those TWO pipes or should i get all 4 pipes?
adrianfromthecastle
Car: 1992 Nissan 240sx
1992MaxSE wrote:could i get away with just replacing those TWO pipes or should i get all 4 pipes?
if it works w/o leaking, go for it. you should be able to use parts of your stock piping (i.e. hot pipe going down).iirc, the only difference between s14 and s13 piping is that the s14 piping has the bov in the cold pipe as opposed to the s13 with the bov on the hawt pipe...I'd just go for the s14 piping just cuz its on the cold pipe closer to the throttle body
CoupedUp
Car: 1993 Coupe
I am just now finishing up an S14 SR into an S13.
Neither the S13 Piping nor S14 piping match up.
You need to cut and weld a custom Hot pipe.
1992MaxSE
so i should get the s14 kit and cut and weld hot pipe to make it work?
adrianfromthecastle
actually, i think you still need parts of your oem hotpipe, just untill the part that goes down to the bumper
1992MaxSE
my swap didnt come with an oem hot pipe. anyone know a good site that will carry oem parts like this? i jus wanna know if i should get the s14 kit and cut and weld hot pipe to make it work? im very thankful for the help im receiving
1992MaxSE
CoupedUp wrote:I am just now finishing up an S14 SR into an S13.
hey coupedup, did you send your wiring out or did you do it yourself?
Tulsa_S-13
Car: 1991 SR 240sx
He did it himself.
