S14 sr idles like crap then leans out and dies.
racers4life77
Car: 98 S14
Ok people i despretly need your help to finally get my car on the road.
Like the title says, my sr blacktop idles like crap, when you listen to it
it surge from 3-400 RPM to1100 RPM for a little then dies. When i look at
my wideband it bounces from rich to very lean and dies, then it takes a
sec to crank back up again, but when i check my plug they look like it's
runnig rich. I've checked and rechecked everything i could.
Any help would be appreciated. And yes i've searched the forums
for two weeks. looking for answers. forgot to mention it did this before the tune and mafs.
ECU: tuned by R.S. Enthalpy.
Wiring done by Yuri at Wiring Specialties
My specs:
Car: 1995 Nissan 240
Engine: 1998 S14 SR20DET VTC
Auto to manual swap.
Rocker Arm Stoppers
Valvesprings
Downpipe
Front Mount Intercooler
HKS: Intake 256 11.5 mm lift Step 2, cam.
Exhaust 264 11.5mm lift Step 2 Cam.
Stock t28
Walbro 255lph fuel pump
3" cat 3" catback exhaust
exhaust manifold
nismo thermostat
List of items checked:
TPS: .45v.
timming: 15*.took off the valve cover and set timmimg per R.S. Enthalpy instructions on site.
New FIVE-O 750cc injectors, o-rings, 2 on the injectors, one on the fuel rail. no leaks.
Gettting fuel and spark. gaps tried, .26 .28 .30 .32 .35 .36 hotter and colder plugs.
New circuit sport fuel rail.
New tial bov: recir.
NO vacum/boost leaks. will check this again today. Boost leak tested.
IACV valve 9.4 ohms, took apart and cleaned, new gasket.
Compression: #1:152, #2:152, #3:153, #4:152.
New Coolant temp sesor.
New walbro pump: even tried hardwiring it.
New throttly body gasket.
Switched to Z32 MAFS after tune. Anybody got a spare one i could test with?
New intake manifold gaskets 2.
New vacum hoses and couplers.
NO exhaust leaks.
Coils good tested.
New fpr w/gauge, tested diffrent fuel pressures from 35.5 psi to 45psi .
This is all i can think off right now. Thanks :gotme
Shadow Drifter
Car: 1990 240sx
This might sound stupid but i didnt' see it listed but check your fuel filter make sure its a z32 one
racers4life77
Car: 98 S14
Ya, it's a new Z32 filter. Thanks.
racers4life77
Car: 98 S14
Ttt
