S14 SR build
JDMGirl
Car: 98 kouki
I'm new here, so I'm sorry if this is the wrong section.
I managed to blow my motor up after only 2 months of it being running since the first rebuild. I will try to update this as much as possible as the build goes on.
Yesterday I FINALLY pulled the rest of the motor and took it apart. It goes to the machine shop Wednesday.
blkvrtswp
Car: 93 240SX Convertible
SR20DET FP 20G Turbo
Ouch, that cylinder! Looks like something got in there - what happened? Are you boosted?
frapjap
'07 Subaru Legacy
You're absolutely in the right place!
And, yikes! Are you planning on keeping the block?
JDMGirl
Car: 98 kouki
blkvrtswp wrote:Ouch, that cylinder! Looks like something got in there - what happened? Are you boosted?
Yes, it's an SR20DET I have a TD06 20g on it right now.
I shifted from 3rd to 2nd while racing. Rocker arms all came apart and messed a bunch of stuff up.
JDMGirl
Car: 98 kouki
frapjap wrote:You're absolutely in the right place!
Oh okay!
WELL, I wasn't at first and my dad went and bought me a block from some guy and when I had taken it all apart, I came to the realization that its no good. We're going to try boring it another 20 over (to make it 40 over) and hope that, that is enough. If it is, we'll be getting the head cnc'd because it's 86 mm and will need to be 87mm. So pretty much if that does work out, it'll be a pretty nice build!
So as of right now, nothing is 100% yet. It goes to the machine shop Wednesday.
Nikita240
Car: SR20DET S13 240sx Hatch
Holy s*** that's some serious damage. Might be a lot easier to just get a block/head combo for relatively cheap than to try and fix that mess.
Also isn't a TD06 like, f*** huge? How much power are you making?
P.S. Get Rocker Arm Stoppers.
JDMGirl
Car: 98 kouki
Nikita240 wrote:Holy s*** that's some serious damage. Might be a lot easier to just get a block/head combo for relatively cheap than to try and fix that mess.
Also isn't a TD06 like, f**king huge? How much power are you making?
That's a relative term, but no. It's a rather small turbo. I already got a new block and head and the block turned out to be bad.
P.S. I had them.
