q45omg »
https://forums.nicoclub.com/q45omg-u45831.html
Thu Mar 15, 2007 7:31 pm
just got done doing this, had my old s14 SE springs lying around and wanted to see how it worked etc. ever since that one guy posted about it.
doing this gives a SEVERE drop. i would only do this on stock shocks because i dont think there are any aftermarket shocks that can handle it and they will all just blow out. i cant imagine doing this with drop springs, the travel is already minimal.
the front - the s14 springs were much shorter, but stiffer. the diameter was slightly smaller on the upper and lower perch but it fits snugly. i went on a short drive and there was no popping. the front shocks on my car are totally blown so i fully removed the bumpstops.
the rear - the springs again are shorter but in the rear they fit like factory. dimension is the same. something is up with the rear that i am not sure about. when i was putting them on the struts i hardly had to compress the spring at all to get the top hat bolted down so the rear springs are slightly loose when the shocks are fully expanded. so when i was driving around the rear springs were popping and stuff. there was a rubber spacer thing in the rear that i assumed was a bumpstop but i guess not. so tomorrow im going to put that on to push on the spring a bit more which i think will fix this. ill post again tomorrow about this. **fixed, my own fault, rear shocks reassembled incorrectly**
to sum it up, the springs do fit, they are stupid low, the car rides pretty good going down the highway, bumps are a little more pronounced but nothing serious, i will probably buy teins or something but will probably roll around like this for fun for a little while
crappy pictures, ill take a few more tomorrow^weird humidity/camera flash thing
Modified by q45omg at 11:13 PM 3/16/2007
