S14 speed sensor pinout 5spd - not going into Nissan
skidsteak
Hey guys. Need a favor here. Trying to swap in a KA 5spd into my LS400, but I'm having a bit of an issue. I have a complete S14 trans going into the car with all the sensors however I don't have the pigtail for the speed sensor, and thus I have no idea which wires would be which on the plug to try and find pinouts. And I did try, and still couldn't find them.
Does anyone have a schematic of the trans wiring harness so I can where the wires are wired to? Luckily both the LS and the S14 used digital speed sensors so fingered crossed they run the same resistance, and it will be just a straight soldering job. Otherwise, well this will suck haha. Now if anyone has transmission sensor pigtails I will gladly buy them from you immediately. I also would also appreciate it if someone could tell me which of the 2 or 3 sensors is the reverse so I can try and wiring that in too. Thanks in advance guys.
If anyones interested, build thread of said car.
http://forums.240sxone.com/showthread.php?p=255000
