:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Thu Apr 28, 2005 7:33 am
Cut the speed wire (it goes to the dash first, then the ECU...so the speedo still works)...and unplug the 5th gear switch.
ECU cuts it at ~116 or so...then the backup is a 5000rpm rev limit in 5th. But with no 5th sensor plugged in, the ECU shouldn't cut it...
I have never done it myself, but have had firends who say it works (they'll put a switch on one of the 5th gear switch wires, so they can cut it "as needed").
Let us know how it goes if you try it.
- Brian
