S14 seats swapping into S13, different bracket?
frenetic
Car: 1993 240sx Coupe
So I have done this before, with the black S14 seats into a hatchback... It has been so long I don't remember if I had to swap rails or anything, but here I am at it again. I have a S13 coupe and some S14 seats. I am to believe that these are the stock rails, but attempting to put them into my car they do not line up.
I search around and some people say I have to swap the rails, some say it bolts right up, some say that 3 holes line up. So far none of these options is the car. If the front lines up on one hole, the opposite side is off by a half inch. The back outside (closest to the door) bolt is about 2 inches forward from where it has to be (see picture) and the back inside, that goes on the floorboard hump, sits flat on the floor (see picture).
On top of this, I cannot swap any rails at all from the S13 seats. Has anyone got photos of how this is supposed to work? Am I being dumb?
Note: Both these photos are with the front inside bolt lined up, the outside one is off by a half inch..
AZ89two4Tsx
They bolt directly up, no modification.
Try messing with the rails so they're even. They might have shifted out of place when you were moving them around.
A pry bar can help too.
PapaSmurf2k3
Site Admin
I left all my bolts loose and fanagled my seats quite a bit, but everything lined up :gotme
S14 blue/grey seats into 91 coupe.
frenetic
Not all bolts line up, the rails are even. The one that is supposed to mount sideways onto the hump is sitting flat on the floor. The one that is on the outside by the door in the back is 2 inches short. It is lined up on the hole in the front. The rail is easily 2 inches short
SoCal-S13
Car: 1984 Z31 50th Anniversary Edition VG30ET
if you are two inches short then slide the other rail forward/backwards 2in. left and right rails move independently. ive had s14 and currently have s15 seats in my s*** BOLT ON NO MODIFICATION.
frenetic
The front one is lined up, both of the front ones almost line up exactly! The back is short. The rail is physically too short.
frenetic
Here is where it sits in the back:
Here is where it sits in the front:
And here is where the back inside one sits, where it should be facing the hump:
SoCal-S13
frenetic wrote:The front one is lined up, both of the front ones almost line up exactly! The back is short. The rail is physically too short.
:facepalm: dood. it fits. pretty sure its on an episode of bill nye.
where do u live. maybe i could come show you my seats and how they fit with no mods.
^^^holy bolt on no mod batman!!!! those are mine. all S chassis seat brackets are the same. im not sure what else you need to hear.
SoCal-S13
ive got S15 rear seats too, now those are definately not bolt on and they need lots of mod.
but the steering wheel and shift knob (with 10mm adapter) fit s13's no problem.
PapaSmurf2k3
Site Admin
The only thing that could have happened is if someone got those seats out of an S14, and put on different seat rails in order to fit their application, and now you got them with some non-original seat rails on them.
frenetic
That is where I stand now. I do not believe these are S14 rails. The kid I bought them from said he got them to put in his vert but they were not direct bolt or something. I found it hard to believe that it would be different from a non-vert.
I am lost here. Now I have to find some S14 seats to mutilate... or whatever. This is getting costly...
EDIT are kouki s14 seats different from zenki s14s?
SoCal-S13
frenetic wrote:That is where I stand now. I do not believe these are S14 rails. The kid I bought them from said he got them to put in his vert but they were not direct bolt or something. I found it hard to believe that it would be different from a non-vert.
ummmm get a set of garbage s13 seats for free. rape the brackets. mount to your grandma padded s14 seats and roll out. COST EFFECTIVE!
frenetic
I still have my s13 seats. The brackets don't mount the same or I would definitely do that. I have these in pieces trying to rig this thing up and it's just... not
edit
are these even S chassis seats? This is getting ridiculous. Never buy things from the internet, folks.
I hate myself right now
Eddiemac
Car: 93 Nissan 240SX vert
Locate a part number, google the part number, and hopefully you get an answer. :dblthumb:
Valiant240sx
Car: 1990 240sx Fastback
I just got some s14 seats yesterday and I swear the side bolsters on my seats are wider, but it could be camera angle also
frenetic
Couple things to note in comparison: the head rest seems wider, and the pattern in the middle goes all the way down the front of the seat, on s14 seats it stops about halfway through the bottom cushion. I am not seeing any markings on here to indicate their origination
SoCal-S13
now were gettin somewhere. id say they weren't but I almost bought a pair with that tiger stripe lookin pattern on em and they were for sure s14's
frenetic
The plastic piece that goes on the outside of the seat at the bottom has a part number "87330-0M000" and the number 97. Searching for this part reveals a part from sentras, 200sx, and even pathfinders. god.
frenetic
Awesome. These bad boys are straight out of a 1997 200SX. FACEPALM
Any way to make them work?
SoCal-S13
the only thing I could think of is that they're from a 200sx which is an altima I think. seats may be the same but the brackets would be different. the altima and the S14 steering wheels are identical too so it is a possibility. that's gay if it is.
frenetic
200SX is basically a 2dr Sentra. I am trying to track down some S14 brackets to try and swap this out, that will be a difficult task.
fiznowler
Car: 97 240sx se, 5 speed, paint, tan leather interior. vg30dett swap in progress.
86 300zx NA Daily Driver
Too many other nissans and parts to list!
that sucks man... I would be getting back ahold of the dumbass that sold them as s14 seats if they aren't. Get monies back and buy some other ones.
frenetic
Yeaaa not a lot I can do. They are nice seats, if I can make a bracket or something for the back brackets. Thanks for your help guys.
PapaSmurf2k3
Site Admin
Buy a welder and modify your brackets.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
PapaSmurf2k3 wrote:Buy a welder and modify your brackets.
That starts an addiction to "fixing" things.
costa_rican13
Car: 1993 s13 coupe
ThiS is true! ;) I "fix" things since I got my welded too.
