S14 seat belt conversion..
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
w1ngzer0
Car: Pfft. i don't own a box
What year S14 seat belt will work in my S13? Just any S14? i didn't know if there was any difference in the years.
JeromeS13
Car: 2008 Subaru Impreza STI
w1ngzer0 wrote:What year S14 seat belt will work in my S13? Just any S14? i didn't know if there was any difference in the years.
All S14 belts are the same. Well, there are different colors, thats it.
driftin8ez
Car: 92 Coupe, Turbo Miata
I often wondered how to go about this "conversion" which is almost more alluring than a front end conversion for us s13 guys. Do you have to drill holes in the pillar behind the front windows to mount the top part of the belt? anyone have pics of it done to there s13?
w1ngzer0
Well when i look at the nissanperformancemag. They didn't say anything on drilling. all i saw them do was take of the plastic panel and bolt the seat belt on. Mabie there is more then meets the eye but we will see this wed when i get paid.
driftin8ez
ok be sure to take some pics if you have a camera of what lies under that plastic panel.
slow s13
Car: cars, photo, music
ive done this conversion and I thought it was simple. The bolt threads are already there behind the plastic panel, you do have to cut a hole in the stock plastic to bring the bolt through. I got a new longer bolt, its an sae size I cant remeber which one if you search some you might find it. here is a pic of the spacers I needed to bring it outside the plastic.
slow s13
very carfully i used a torch to heat and bend the plastic to allow space for the seat belt to pass through
slow s13
heres a bracket i made for the upper mounting point of the seatbelt real
slow s13
side shot of new bolt
w1ngzer0
lol damn you. You beat me >_<. But awsome none the less
So what did you buy a seat belt assembly from the junkyard? or what? Can you make a list so i can go shopping?:D
slow s13
looks stock besides the gap for the power sliders, you do have to make a hole in the carpet for the lower belt mounting point again the threaded hold is there but unused. I removed all the power stuff the sliders and both reels computer and wiring and there is some significant weight in all the parts combined.
w1ngzer0
but i meen does it feel like a normal manual seat belt should feel? Which should be sholder to bum. Not neck to stomic.
slow s13
I got my belts off ebay, but if you can find an s14 at the junk yard you'll be set. Besides the belts the only thing I had to get was the bolt and the 2 spacers the black spacer in the picture comes on the belts.
w1ngzer0
it would be really helpful to tell me what the sizes for the bolt and the other things.
slow s13
feels fine to me, I mean as far as i know this is the exact mounting points used in the non power setup.
w1ngzer0
kewl. I get paid today so ill be doing the same thing.
VA240
slow s13 wrote:looks stock besides the gap for the power sliders, you do have to make a hole in the carpet for the lower belt mounting point again the threaded hold is there but unused. I removed all the power stuff the sliders and both reels computer and wiring and there is some significant weight in all the parts combined.
That's the cleanest manual belt conversion I've ever seen. Great job!
-VA240
JY116
Car: autoX
kudos!
w1ngzer0
my question is. It looks like its just dangling there in the back... Or is that just stretching it out so you can get it through the panel and through the bracket up top?
Aznboi64
Anyone know if the 180sx seat belt bolts right in without any modifications? I saw it at the junkyard. Here is a pic.
Red coupe
Car: 92 Nissan 240sx Coupe
Aproximately what size would the bolt up top be any guess in metric if you cant remember the sae? reason I ask is if you crash its going to pull real hard on the bolt, and with it sticking away from the frame like that it kind of looks like it could snap the bolt...
Return to “Interiors”
