S14 SE Wheels clear R33 front calipers?
Teh Luckinator
Car: 1995 240sx
I'm finally converting my S14 to 5 lug, and I have an offer of taking some S14 SE wheels with the hubs. In the beginning I didn't think SE wheels would clear anything, but then I remembered,
My friend with an S13 hatchback AND Z32 front calipers had SE wheels on.
So now I'm wondering, with the current R33 calipers I have up front, will SE wheels clear these as well? I don't know the size difference between Z32 and R33 calipers, but since the R33 GTR wheel sizes are 17x9 +30, I wouldn't think they would clear. Not sure though, so someone please educated me, thanks.
And also, to do a base model S14 into 5 lug, all I need are hubs and rotors, not the spindles, not even the front, right? (My current R33 rotors were redrilled to 4 lug, yeah, lame.)
Teh Luckinator
Car: 1995 240sx
I also forgot to mention that I have Tein HA's, so coilover clearance is an issue as well.
SmithSR
Car: 240sx
The r33 brakes are the same as z32 calipers.
S14 Se wheels fit perfectly on those calipers and with coilovers. Almost like they planned it that way.
jgauspohl
Car: 97' S14 SR24VET
92' S13 S14 SR20DET
90' Golf GTI
91' S13 siltruck project
the r33 gts-t calipers are 30mm I found out as well..yes to the moderator...but the gtr version in the R chasiss's are 32mm...the r32 using a 296 diameter and the r33 and r34 using a larger diameter than 296..forgot the exact spec. If you have either the 30mm or the 32 they'll both clear on the gtr wheels...of course you'll need a spacer...I've been doing this research because I'm trying to upgrade mine to 32mm calipers and r33 17's as well for the "yam" effect! oh **** a rabbit...sssskkkkeeeet!
cdlong
Car: '95 240sx
luckinator, do you have the GTR brakes? if so can you post some pics?
i think the gtr rotors are 315mm. check the catalogue on http://www.DBA.com.au.
sorry, wrong link.
Modified by cdlong at 10:33 AM 6/21/2006
jgauspohl
92' S13 S14 SR20DET
90' Golf GTI
324mm.
