S14 SE VLSD question
ColumbusDrift
Car: 96 S14 KA24DET
So I'm looking at buying an S14 SE. Vehicle was built 11/95, but is classified as a 96 Model Year.
Can I check to see if it has VLSD by using one of the digits/letters in the VIN?
Thanks for your support.
I search and couldn't find the answer. I remember seeing a similar method a couple of months ago.
BoBa524
Car: 1995 Nissan 240SX SE
no, it was an option. just do a quick burnout on a test drive.
xweav32
Car: 2011 Nissan Versa S 6spd (daily)
1995 Nissan 240SX SR20DET 5spd (fun car)
thers a orange sticker on the subframe. the MIN tells you options.
Shift_Kouki
Car: 95 Nissan 240SX SE
I'm fairly certain that all the VLSD's had little cooling fins on the back cover.
Unless the housing / casing was switched, it should give you a good starting point along w/ the above mentioned sticker.
I'd still turn the wheel to lock and bury the right pedal just to make sure its there and still works right.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Take a jack, put it under the pumpkin, raise car up, spin a rear wheel. If they spin in the same direction you have vlsd, if they don't you have open...or look for the orange sticker on the pumpkin or subframe, usually stuck to the diff cover. Too easy and been covered many times.
ColumbusDrift
Car: 96 S14 KA24DET
I know about the wheel turning method. I guess I'll have to resort to that method since there is no sticker.
Also the clutch is blown, thus I won't be able to do any burnouts.
The reason that I ask is I have the VIN and the car is 75 miles away.
98s14inaz
If the price is right just buy the car anyway. VLSD's are $300 or less and take less an hour to install. If you get an r33 vlsd and r33 axles you won't even need to swap driveshafts.
ColumbusDrift
Car: 96 S14 KA24DET
You are right. The price is probably right on this one. It is the SE model with a clean body and no suspension modifications. Vehicle already has KA24DET power and basically just needs a clutch.
98s14inaz
Compression check the motor and find out what kind of tuning he has. ka-t guys only sell their cars when there is something wrong with them and or out of money...lol Trust me I know.
