verSat1l3 »
https://forums.nicoclub.com/versat1l3-u70359.html
Tue May 13, 2008 1:42 pm
Okay, so I am getting ready to do my 5sp swap in my 96 SE. I have all the parts here or on order except for the rubber boots that cover the shifter which I will pick up soon.
I currently have the motor and trans out of the car. I want to get the wiring straight before it goes in. I bought a manual transmission harness to make the wiring easier. Everyone says it will plug right in, but it definitely doesn't appear that way...
***IF ANYONE NEEDS PICTURES OR DIAGRAMS TELL ME***FSM Page EL-223 shows the transmission harness.FSM Pages EL-220 - 221 show the engine room harness.
What is present in my auto engine bay:E12, E13, E14, E15 are all present. I assume these remain unhooked as they are all AT related. E19, which is present for both MT and AT has 4 wires. E16 which is AT only, has 2 wires. E18 is nowhere to be found. I suspect it may be a ground wire?
On my manual harness:E205 and E207 are shown as present in the FSM, but I have only 1 of those ring terminals... E203 which plugs into E19 from above has 7 wires. E201 which plugs into E17(not present in my auto) has 3 wires. E204 plugs into the missing E18 from above and has 1 wire.
My guess is that E201 (MT 3 wires) should get spliced to E16 (AT 2 wires), but I'm guessing, and wouldn't know which 2 to splice and what to do with the 3rd. What is the deal with E203 to E19? What are the extra 3 wires that are not getting connected? And where/what is E18? Do I just connect E204 -which is 1 wire- to ground? What else could 1 wire be doing(I know knock sensor is 1 wire...)?
HELP!
