1SickSilvia wrote:I just received my 5 lug swap for my S13 coupe from a S14 SE donor. I searched , but could not find the answer I'm looking for.
Since I have never seen S14 SE Brakes , could someone show me a pic of one, because the calipers I got with the conversion looks just like the S13's single piston s***ty calipers. Is that what the S14 SE came with????? I thought the S14 SE front calipers were 4 piston and had Nissan printed in them, is that correct? Any help would be apprechiated. I can post pics of what I got if that helps.thanks
you got the right calipers. s13 and s14 brakes are the same thing, abs equipped models are a tad larger iirc. if you want 4-piston fronts and 2 piston rears, you need to upgrade to z32 brakes or skyline brakes. sorry bub.
