s14 saga please help
wannaBdrifter215
Car: 95 240se
HELLO ALL , i have a question about s13 in a s14 ..#1 my wipers only work on high , as does the heater , no radio ..and the right side of my cluster does not work (speedo , gas .) but the left does ..i did not do the swap bought it like this and was not too concerned with those little things ..but now i am curious ..i am also seeing the coolant temp start to spike when i am at a light but once i go it goes right back down ..is this the water pump or thermostat ..gauge ? im not sure i also have a garbage alum. rad . that the idoit put in that does not fit i have one on the way..the car is also (desiling) when shut off for 1-2 seconds ..any help or things too check would be great .. thanks glenn
stopatnothing
Car: Scooty Puff Jr. and NEW! Scooty Puff Sr.
It sounds like a piss-poor wiring job to me, other than that, the post was a little confusing so I'm not sure exactly what you were getting at.... Did you mean you put an s13 motor in an s14? Or what?
