BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Sun Feb 15, 2004 8:21 pm
I am helping a friend with his S14sr into an S14, and we've hit a problem. The car cranks, gets fuel, but absolutely no spark. I tested his ignitor on my SR and it works fine, I hit the plugs to the coil packs with the test lamp and there is a ground, a constant, and when he turns the key the other wire causes the test lamp to flash like it should, but there is still no spark. I removed a plug and coil pack, grounded the plug and it didn't spark. I removed the plug, put my test lamp in the end of the coil pack, and it didn't light when we cranked the car.
So from what I can tell, we are getting power, and signal to the coils, but nothing out of them. I can't however, imagine all the coil packs failing to fire with power, signal, and ground.
Is there somethign I'm not thinking about, or something I'm missing?
