s14-s13 VLSD swap Question
Drk_Drftr
I already have a vlsd from a 92' s13, it's getting worn out so I'm gonna trade my friend for his vlsd out of a 95' s14.
Will i need to make any modifications to the s14 diff to fit in my s13? Or does it just bolt up?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Just swap the rear cover. That's a pretty nice friend to just 'trade' you.
Drk_Drftr
c-rad wrote:Just swap the rear cover. That's a pretty nice friend to just 'trade' you.
ok because i've been reading that the front bushings dont bolt up to the s13 subframe. Oh yeah about that, hes selling his car and so i asked for his diff cuz mine is all worn and the guy buyin his car wont know kinda shady of us huh?
scheffler
Car: 92 240 KA-T
92 300zx TT
97 Tahoe
haha that is shady when i put in the 300zx dii in my s13 the front bushings would not line up for some reason dont know? so i am going to try to put the 300zx egg into the 240 shell?
Drk_Drftr
scheffler wrote:when i put in the 300zx dii in my s13 the front bushings would not line up for some reason dont know?
yeah thats the problem with the diff i have, the front bushings from the s13 diff look totally different from the s14 and i dont know if they will line up. The s14 pumpkin i have has 2 bolts on the rear cover, and two large soild (no bushings) holes up front, it also has the sensor for the ABS. I just need to know what i need to do to make this thing fit, i'm having drifting withdrawl!!!!
c-rad
Drk_Drftr wrote:yeah thats the problem with the diff i have, the front bushings from the s13 diff look totally different from the s14 and i dont know if they will line up. The s14 pumpkin i have has 2 bolts on the rear cover, and two large soild (no bushings) holes up front, it also has the sensor for the ABS. I just need to know what i need to do to make this thing fit, i'm having drifting withdrawl!!!!
You need to use some thickass washers between the diff and the mount.
Drk_Drftr
sounds like washers should work but the holes are huge! like an inch wide, i've been thinking that this might be where i need to press in my stock bushings.....
Nismo_Freak
Car: 89 Nissan 240SX
You can always swap the guts.
