s14 s13 speed sensor connector question
Blackstar
Car: 1995 240sx
I"ve got an s14 w/ an auto to manual swap done, but using an s13 transmission. My speedo and odo are showing double so I bought an s14 manual speed sensor. Got it today and saw that the connector is different, the s13 one looks like the wire is hardwired to the sensor. so if I cut it, Ill have nothing to connect it to on the s14 sensor. is my only option getting a whole new s14 trans harness or is there a way to make it work with what I've got? also, if I could get ahold of only the auto s14 trans harness, is the connector the same? could I just cut the connector off and use it w/ the manual sensor? any help would much appreciated
180fan
Car: 89 fastback
check the plug further up the transmission harness. it should NOT be hardwired.
bartyb
Car: 98 Nissan 240sx SE, 95 SE, 91 s13, 89 s13, 03 Sentra SE-R
I had the same issue (s14 transmission with s13 sensor), I just cut the wire, soldered, double heat shrinked, taped and loomed and retaped the new s14 speed sensor, and it works like a charm. I don't see why you would get a new harness, just cut and solder away. I believe the speed sensor is sending square waves anyways, so it's not a resistive circuit.
Blackstar
Car: 1995 240sx
cool, thanks
Maxz0rs
Car: 1996 Nissan 240sx SR20DET GT28
do you still have the S14 speed sensor? if so ill buy it off you.
