Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Fri Apr 29, 2005 12:05 pm
I want to say that it is on the latch itself. If you open your trunk and look down at the latch, you will see a little lever that sits horizontal. It is maybe only 1/4" long, so it is small. I know that when my trunk latch on my Maxima was not aligned and I could not open the trunk, I had to fit through the trunk to open it by hitting that lever. So, maybe pushing the lever down will lock the trunk.
If you cannot find it, or what I am talking about is not the remote trunk lockout switch, you could always disable the cable at the actual trunk switch next to your driver's side seat. I think it is just plain and simply held on by a 10mm nut. Or you could disable the line at the latch area....
