s14 rear sway bar
AkiraP
Car: 1996 240sx
will the rear sway bar off of a 97 240sx se work on a 96 base model?
KFL
Car: S14
Yes it will.
AkiraP
Car: 1996 240sx
do i need 2 get anything from the dealer for it 2 work or it should just bolt up with the bushings and the d shaped brackets?
cdlong
Car: '95 240sx
as long as you get all the stock parts you should be fine. make sure you get the d brackets and bushings to mount the bar.
