S14 Rear Seats into S13 Hatch: FULL HOW TO GUIDE!
NICO's official source for Nissan upholstery, carpet, headliners, and trim information!
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
well ive searched and never found any actual guide on how to do it so ill post up my modifications.
mods please sticky...pretty sure its worthy! :biggrin:
1st: remove plastic retainers & cover the whole. i used gorilla duct tape.
2nd: you need 2 M8-1.25 X 65MM long bolts w/ washer behind head.
qty ( 2 ) 3/8 ID 2"long spacers
4 thick washers on each side of seat that add up to 5/16 spacer or try to find a spacer that size...i didnt have.
tighten into factory threaded hinge
3rd: use factory seat latch and flip upside down...measure 5" up from straight indented line in metal.
use 10mm bolt w/ lock nut and tighten down latch.
seat should lock into place if done as showed.
4th: push bottom section of seat as far up as you can so its even. hammer the u-shaped metal piece over and use 5/16 self drilling screw w/ washer and tighten down.
5th: use the same shape self drilling bolt & washer combo and screw the metal bracket flat against seat ledge.
6th: you need to find some foam to put under middle of seat, because there is no support there. ENJOY your updated look!
Klits562
Car: white s13 coupe
would this work in a coupe or only hatch?
splintercell
Klits562 wrote:would this work in a coupe or only hatch?
idk about a coupe only hatchback...sorry.
heres an update for bottom cushion metal tab: i happened to ride in an s14 a few weeks ago and i peeped the rear seat too see how the metal tab was covered and ordered the appropriate part.
cover 88327- 65F00
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
nice
EatSleepNissan
Car: 1990 240SX sileigthy
I need the pictures for this how to! They arent showing up and i just bought some seats. Please help?
splintercell
EatSleepNissan wrote:I need the pictures for this how to! They arent showing up and i just bought some seats. Please help?
Ill rehost them tonite...my photobucket was hacked and this was the last thread i need to fix.
The_caveman
Car: 93 nissan 240sx hatch(daily build)
1992 Coupe (drift build)
1990 240sx hatch(wrecked slut)
2008 hyundai sonota - girls car/reliable! i drive it better tho ;)
Doing this tonight lol picked up the back seat for free tonight
93_1via
Car: USDM 240sx S13 coupe
I second that!! Please post those pics again, I probably could figure it out because of the nicely detailed post :bigthumb: but pictures are the best way to confirm I'm on the right track. Thank you!!
Return to “Interiors”
