Since this seems to be very guarded info, if anybody doesn't feel like posting something in here but would like to help please PM, AIM or E-mail meAIM = Dubmaster TEmail =
[email protected]
1. My main question is: i know i'm supposed to repin the RB white plug to match the S14 F3 plug. Does this mean i completely remove the harness from the ECU and F3 plug going to the engine part of the KA harness and replace it with the RB's ECU and whiteplug to engine harness. I noticed the wipers are on that KA harness so are they the same plug and pinout as the plug on the Rb thats in the same position.
2. One other thing i didn't quite understand, the oil pressure wires(2 of them one i think is green and the other i think is blue) i removed them from the RB lower harness. Do they go straight to the cluster or do they go to the ECU then cluster. And just to double check, the knock sensor plug connects to another plug on the engine harness right?
3. The plug by the firewall next to heater hoses and fuel filter that connects the lower harness to the upper harness, does that just get replaced by a similar plug from the RB harness or do i need to splice wires
i also just noticed that i don't have a boost control valve(solenoid?). From what i read, i don't necessarily have to have it.
Thanks for the help.
