s14 + rb25 + non electric fan
NotDave
Car: 96 240sx that needs paint
and i thought you had to switch to dual electrics
eh?
Doesn't overheat during a hard run?
dekand
Car: 1995 240sx SE
what is up with that pipe ... that thing is tortured...
Nameless EJ6
Car: What the **** do you think.
Repost from another forum.
JonPowell
Car: Cars, Music, My family
I believe that is a KA fan clutch with 10MM spacers to keep the fan from hitting another pulley. I think the McKinney mounts were used also.
FAST-DATSUN
You MUST use the fan shrould to make the manual fan work correctly there designed to work together and leaving the shrould offf is asking for trouble down the road.....
BoostFab
Car: S13cp, S13fb, S14z
i'm affraid it will hit the radiator on hard turns or launch
goofynick6
Car: 1995 S14.5 RB20DET
I was gonna say, w/o that shroud, it's going to pull air in from where there is the least resistance, like the sides of the radiator. It'll help, but be careful.
Nick
Joe
im gonna repeat what mack said, you MUST use a fan shroud, if you dont the mechanical fan will not pull any air through the radiator.
