andy107 »
https://forums.nicoclub.com/andy107-u117580.html
Thu May 21, 2009 10:24 am
Thank you sir. Both the tach and speedo works. Checked and fixed all connections. I had two yellow w/blue stripe gray dot leads on the R33 cluster for the tach. Not sure why but both show continuity on the ohm meter to and from the cluster, so I wired both to blue w/black stripe leads on the 240 cluster harness. Works great now.
As for the speedo I looked around the web and found where the speed input and ground is located for the VSS. "Pic shown on the bottom." Its not my pic but can't remember where I found it. Traced the input signal for the VSS on the R33 cluster to be gray w/red stripe. On my cluster I had two of the same gray/red stripe wires. One for the fuel gauge and the other for speed input. The gray/red stripe goes to the red/yellow stripe on the 240 harness. On the 240 harness there are two red/yellow stripe wires one from the VSS and the other for ground side cluster back light dimmer. Wired those accordingly. The red wire coming from the 240 harness is the ground side from the VSS. I found out it was ground by looking at my s14 cluster and traced the leads on the printed circuit to one of the "ground sided" screws holding the speedo gauge. Same went for the R33 cluster and found ground side VSS lead to be brown w/yellow stripe. Put everything back in and test drove GREAT. I don't know why Nissan uses two of the same colored leads for different components. For those who are doing this project. Don't forget to cap off "hot at all times or when on" wires such as the clock and lumination circuit. Use shrink wrap if possible.
The only thing I did not connect is boost, oil gauge, cruse and air bag light. I believe the cruse and air bag circuit on the cluster is different. I may be wrong. If you look at pic below, The air bag light has an external lead wired to the back side of the R33 cluster. Oil gauge needs oil pressure sensor from the RB or possibly a 300ZX. The 240 has only the pressure switch. Boost gauge needs the boost sensor and to wire that I may have to look at how the 300ZX is wired. Can’t seem to find a service manual for skylines on the cluster but seems that the nissans for the s14 generations are almost the same in some aspects. Looking at how the 300Z’s boost gauge is wired, there is 2 wires going directly to the cluster from the sensor and one wire for power. Total of 3 wires. Instead of using a 5 volt reference like most. This boost sensor seem to use full battery voltage with a 30amp fuse inline to it after splitting power to another relay for bulb check. Power, signal and ground are the 3 wires. Run wires from the sensor through your firewall to the cluster and match the color of the wire on the sensor pigtail and on your R33 cluster for ground and signal. Check by tracing the circuit. Then the remaining wire should respectively be for power if it is wired exactly like the 300zx. Don’t forget to add fuse if you are not tapping from the fuse box. This is all just an assumption, don’t take my word for it.
A little side note: Looking at 300plus.net’s diagram. The door light leads can be Blue w/red stripe for SE models and Red w/white stripe for others I believe. Also if your cluster back light don’t work make sure you are using the correct red w/blue stripe leads. There’s two, one for washer level and the other to power your cluster back light. The ground side of the back light uses 2 of the 3 ground leads on the R33 cluster going to red w/yellow stripe. Make sure its the correct ground lead by tracing the printed circuit next to the lettering “ILL-“ . I found out the hard way. Sorry if this is a long write up but I hope this may help someone. My wiring may be different compared to yours so its always good to look at wiring diagrams. Good luck.
Modified by andy107 at 9:16 PM 5/21/2009
