Yeah that's ehacker's guide that I expanded upon. You are on the right track. If you followed that, then your wiring is right and your ECU will not fry. If you were sloppy, there are no guarantees
tek747 wrote:I found the GREY (AF81) wire! ... Is the grey wire power??
Yes!
NV11 and CC30 do not technically "meet" AF21 and AF14. It is a method Nissan uses to consolidate the wiring diagram so 100 individual wires/lines are not shown.
I still have no idea where the yellow and black wires are from. I know for sure that it DOES NOT go to the yellow ECCS/H NO.2 wire. That is the fuel injector harness and would make absolutely no sense.
Is the yellow wire located in that same 8-pin plug that the grey wire is in? If so, forget it. Don't need it.
