craz4240 »
https://forums.nicoclub.com/craz4240-u47081.html
Mon Jun 16, 2008 1:20 pm
Well long road.Posted on this subject a couple times talked to Carl about it a few times but now it's down to the wire and looking for ideas that may support or possibly object my own.
Car is a 95 240sxPowerplant is RB20DET
equipped with Z32 MAFS,GTR FMIC,2.5" Cooler piping,t-bolt clamps,RX-7 Series 5 Injectors,Custom Built RB25 Turbo,Toyota Supra Lower Injector Isolators,Carl H tune.
K well the car idles at 22.4:1 AFR's and seems to be a little over the map under load.I have had the injectors flow tested and cleaned,all new gaskets for the IAC,TB,Intake upper and lower plenum,supra lower isolators,New hoses for all vacum lines,injectors tested for power and pulse,spark operating fine,CAS operating as it should.Car fires first try but the lean idle alarms me,also it's not really drivable,seems to work better when cold as opposed to once it gets hott.
For the record I had all the same problems b4 I did the gaskets,flowed and cleaned injectors,added GNX coil upgrade.
I still have someone bringing me a spare Z32 MAFS to try out tomorrow,and i plan on just plugging in a stock tune adjusted for MAFS and Injectors Only see how it idles.
Sorry for the long winded explanation but theres alot going on here hehe.Any advice or suggestions would be appreciated.
