Wulfgang wrote:I have an S14 with RB20.
Just to give you some idea... we just had a warm snap here in Illinois (up in the 40's). I took the fan relay out of my car (turned the fan off) and went out for some launch practice and to get some 0-60 times. After about 25 minutes of thrashing it, the engine was still cool... hadn't even warmed up to normal yet.
And last summer, with just 1 Perma-Cool 12", it took over 15 minutes to reach normal temps while driving. Obviously that is too much cooling.
This is with stock KA radiator and no condenser (yet).
Yellowjacket is right. You've got bigger problems. Did you replace the waterpump/thermostat yet?
I am running two of those Wulf... and mine operates at the normal temp level on the stock gauge. Before I replaced the old KA sending unit with a new one (~$20 at the Nissan dealer) it use to look like it would take forever to warm up. Once it did warm up with the old sending unit, it would read really cool... not anymore... now it's usually always normal. This is in 70+ degree weather back in the summer. Unless I'm heading down the highway I usually have to keep the fans on in warm weather... haven't had to many chances to drive it this winter.
These fans do the trick, and I would definitely recommend them. My buddy's car is running 2 10" fans from autozone and his is doing fine in the same kind of weather... we tend to run the fans all of the time, but his has been ok at points in cold weather (this is Hybridone's S14.5 who has sold his to another friend of ours... we got it running back in 03). Both of our cars have Hybrid FMIC's and still do well temp wise in the summer with the fans running.
Look at the link in my signature to see how my fans are mounted... be sure to run a 30 amp relay when you hook them up. Good luck bud...
