Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Mon May 09, 2005 3:38 am
Ah, I thought you guys had cruise. Well, I've done some research and wasted some money trying to make cruise work. Here's what I've found:
KA TB won't work due to obvious reasons (it's cable is mounted on the opposite side and throat is too small).
The TB from a 92-93 Pathfinder (auto with cruise) is a direct fit except for some coolant line mods. However, it's throat is also too small, and swapping the cruise related parts to the RB TB does not work because the shaft is a different length and configuration. If you could fab a new shaft, it would probably work. But that's a lot of work just to get cruise control.
And this: I've looked all over the internet for pics of RB20DETs from GTS-Ts and I have yet to find one with cruise. However, it seems that ALL Cefiros with RB20DET had cruise (which must be why our TB cable brackets have that extra slot). I am not sure if the throat diameter is the same size (why wouldn't it be?), but maybe I'll hit up Venus and see if they have anything lying around.
Yeah, that adapter plate would be a good idea, but there is not really much room if you use the stock intake piping. There's just a short, maybe 4", piece of rubber hose connecting the TB to the intake pipe.
Again, sorry for hijacking the thread.
