Winchell s14 »
https://forums.nicoclub.com/winchell-s14-u239511.html
Wed Jul 30, 2014 10:00 am
Okay so I'm new to the whole rb thing and I recently bought a rb20 swap for my s14. The problem is that it will not start!!
What it does: turns over and over and over but does not actually start. If I advance or retard timing it will backfire through exhaust or intake but that's all it does.
What I've done so far:
Check spark and each coil is getting one injectors are working as well. I can spin the cas and see each one squirt fuel out. I've tried using starting fluid and nothing. Timing, I've double checked even took belt off and reinstalled every thing just to be sure. So physical timing is good. The half moon shape piece in cas is fine so that's not broke.
What might be wrong:
Have a few vacuum hoses not hooked up but have them blocked for the moment.
The two sensors below intake manifold that go into the block are not hooked up bc I don't have a lower harness for transmission if that matters.
But other that every thing is good I believe.
Any idea??? I'm stumped and need this car running.
