s14 rb swap a few wires left,... help plz
daveh93s13
Car: 96 240sx se coupe
in wiring my rb20 in my s14, i have a few wires left im not sure about. i got the pin out charts and found that there are a few wires that share the same color. so basically im not sure what to splice in to what. i found some go to the consult receive, consolt clock etc. but there are several others left to be wired. i took a couple of pics to show what im working with....
the first image wires are: L/BLKY/GREY DOTBLK/YY/BRN or PU (hard to make out the color)Y/GRNY/RLT GRN/REDBLK/GREY DOT^^ those wirers are the ones that my fingers are holding
the second (white) connector in the first pic, has:BLK/GREY DOTWHT/GREY DOTGRN/WHT(the orange and green wires were cut to be spliced in for wipers)
pic # 2 wires in somewhat counter clockwise order:LT GRN/ GREY DOTBRNY/GRNBLK/YY/RO/BLK
thanks
Modified by daveh93s13 at 7:26 PM 5/3/2008
s13point5
Car: 89 240sx
go to http://www.photobucket.com and sign up for an account. upload your pics. then post the pics here.
daveh93s13
pics added....thanks
Modified by daveh93s13 at 8:18 PM 5/3/2008
daveh93s13
bahhhmp
daveh93s13
hello? bump? help please,....... also my wipers are wired in but only work on low, not high or int. its a 96 se s14, and it has a gd wiper amp. i got another one to test and make sure.. talk about stumped.... theres gotta be someone on mhere that can help..
S13 240SX
Car: 93 Mazda Miata
daveh93s13 wrote: hello? bump? help please,....... also my wipers are wired in but only work on low, not high or int. its a 96 se s14, and it has a gd wiper amp. i got another one to test and make sure.. talk about stumped.... theres gotta be someone on mhere that can help..
i dunno man those white plugs.. i think only the 1 is needed which you wire some of wires coming off to the brown or white 240 dash plug. the cosult port plug dont worry about it unless u actually wanna do that.
but ur gonna find out most people wont help us on wiring..becasue there's a write-up on here.
daveh93s13
well i searched numerous times and dont find these wires points of connection. the write ups on here are very helpful but they donnot show where the few wires i have left go.. so if you know of the writeups, just plz post the link here. thanks alot!!
S13 240SX
Car: 93 Mazda Miata
http://www.racebread.com/old/Documents/harness.swf
should tell ya everything you need to wire for chassis plugs and dashboard plug.
need a swf player to view link so make sure you have some type of thing installed on your comptuer for viewing it.
mello88
Car: s13
S13 240SX wrote:http://www.racebread.com/old/Documents/harness.swf
That link/file is 404. Please re-host it if you have it or update your link
S13 240SX
Car: 93 Mazda Miata
it should work it still opens for me.
PorkChopExpress
Car: rb kouki
blue/b thermal transmitter y txb/y air regulator/or ign switchy/pu chky/g rxy/r tachlg/r ac switchb ground
lg ac relay or ac engine temp temp sensorbr o2 heater powerb/y ign switch / or air regulatory/r tachor/b check engine lamp
