The car.
Our plan is to build the KA24DE that came with the car as a naturally aspirated motor to start. Once that’s in and running we will sort out any chassis problems, get her PA inspected (emissions testing sucks) and go from there. Vehicle has everything there for turbo install, which will happen after we have the basics sorted out. And the garage cleaned out (selling CRF250R, keeping quad)
Still in the process of inventory, we bought all/everything that the prior owner had for the car. The first step on the build is tear down of motor, and it’s a bit rough. Lots of stripped bolts, weak oil return fitting in oil pan, ect.. So everything that comes off motor is at machine shop, hot tanked and correct fitting installed in pan. Once I get parts back its helicoil time!
