s14 problem and question
cr0nict0k3
I just bought a 95 s14 with a auto transmission and the reverse is out, does anyone know what that could be? And is there instructions on how to run a oil line to a turbo and what parts you would need? Thanks
MAGILLA
Car: 95' 240 se
If I were you I would swap to a 5 speed trans. it would most likely cost the same as getting the auto repaired, Or find some one who has done the swap and buy their auto. I would sell you mine for cheap( case of beer) but I doubt you would want to pay the shipping.
MAGILLA
Car: 95' 240 se
just a silly question. You did check the trans fluid level? if it is low it could cause hard shifting and possiblely your problem.
cr0nict0k3
ah i deffinently want a 5 speed just wondering if i can fix that in the meantime, i got qouted 1500 on a 5speed swap hahah i only payed 800 bucks for the car what a ripoff for a transmission
s14kouki
Car: 1998 240SX SE
swap for the 5 speed, look around for parts and swap it yourself if you can.
