s14 power window not working
RBpowered_240
Car: RB25 240sx s14
I posted this problem a month or so ago. My passenger side window all of a sudden stopped working. I can apply direct power from the battery and it goes up just fine. I have power going to the switch on the passenger side all the way up to the plug where the PW motor plugs into the wiring harness. The power is also going to the motor, all fuses are good, and the relay as well. I have swapped out the switch on the passenger side, and on the drivers side, since that switch has the amp built into it. The switch on the drivers side came out of a known working car, swapped it with a friend to test. Still no luck in getting it worked out. If there is anyone that has any suggestions on what else I need to do I would greatly appreciate the help. Also if anyone could tell me where I could take it to have someone look at it for me if I cannot get the problem figured out.
vancouverbc
Car: 1991 240sx
go to the original thread and read again. the wiring for 96 is very easy.
