S14 power window dead? Quick question
Explodicide
Car: '95 240sx
Sorry for posting about an issue that's been covered a million times, but I just wanted to make sure that I'm testing the correct connector. I've not been able to actually get the motor / regulator assembly out of the door to test it properly.
Drive side power window is dead. The amp clicks when the switch is pressed, but nothing from the motor. I thought that the amp might be the problem 'cause I've taken the amp out before, checked for blown connections, put it back together, and had it work for a week, but now, no go. I've tested the harness and connectors, and I'm getting continuity / ground / power where I need it.
The FSM and other posts on this forum say to connect the battery straight to the motor itself and see if you get anything. Since I can't get the motor out, can anyone confirm that this is the right connector to connect to the battery?
When I connect it to the battery the connection sparks a little, so I know that there's power flowing, but I get nothing from the motor. It's a 2-wire connector, with one green and one purple wire.
Thanks in advance for the replies.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
i'm going through the same exact thing right now, and yes, that is the right connector. i just bought a motor only to find out that the one that was in there was good. i'm thinking it just might be the amp because i tested all the wires and they all seem good. it's funny because every part store i call has never heard of a power window amp.
