S14 Power Steering High Pressure Hose fit on S13?
Idahos13
Car: 93 240sx hatchback
Hey guys, my High Pressure hose on my S13 has a slice in it, so it leaks quite a bit of fluid and I'm getting tired of refilling my power steering. I am wondering if the S14 high pressure hose will fit on the S13? Are the hoses exactly the same? Seeing as they both have the same motor but slight differences. Thanks for your help in advance!
super240sx7185
Yes you can use a s14 hose but it is one piece all the way to the rack so you will need to remove all the s13 hose all the way to the rack then swap it.
